Posted by member Simon Papendick on Wednesday 19 August 2026
Hi Henry,
I have over the years fitted floor inspection hatches in the floor ahead of the outboard well sump. The normal size is a 100mm inspection hatch you can get from most marine outlets. The position is approx 600mm ahead of the forward face of the outboard ell sump. This will give you the access to the bilge area under the floor and u=you should be able to pump out any water in this area of the bilge.
Posted by member Henry on Friday 17 April 2026
Hi Guys
I have a Navigator, with a similar set-up. However, I'm not convinced that the "hidden bilges" underneath the stern lockers are fully draining into the centre well.
Is this a "design feature" or just that I haven't yet found a way to inspect them ?
Cheers Henry
Posted by member Hardy Editor on Sunday 24 May 2015
Ahoy Robert,
You are correct. My Pilot is an 1984, and the same set up.
The inspection hatch will enable you to empty any water collecting in the bilges.
HOC
Editor
Posted by member Robert Sneddon on Sunday 24 May 2015
Hi Ron. My Pilot 20 is a 1986 and it sounds like your set up is similar to mine.
I have the round inspection hatch which sits vertical in the centre of the drop down to the rear stern well.
Then I have the two thumb screws either side at the rear and below the stern lockers. There is bilge space under there and my understanding is that this will allow drainage into the centre well.
Kind regards, Robert.
Posted by member Ron Clarke on Saturday 23 May 2015
Hi guys,
I have a question that I need to ask our members that may sound rather silly but I need to ask anyhow. I have a Hardy Pilot 20 SE built in 1999. To the rear of the cockpit on the floor is a circular plastic threaded disc (around 6" in diameter) this I'm sure is an inspection plate that enables one to check the general condition beneath the floor, and this is fine. However, further to the rear of the boat and right at the back of the well are two threaded thumbscrew type units, one either side of the well that I know don't go through to the outside of the boat. Am I right therefore in assuming that these are drainage ports for any water that may have found itself underneath the floor?
Ron
